John M.
Well, I collected the car last Saturday week after it's service and have since done close on 800 miles (mixed driving with some rapid motorway blasts), it's driving very well too and I'm happy with the mpg, averaging 35. As you can see from my original post on the car I wasn't happy with the suspension or the steering but as there was no faults found while the service was being done and no faults recorded at it's NCT test (MoT) 2,000 miles prior, I've put these 'issues' down to characteristics of these Accords compared to the likes of the Mazda & Merc I was driving but, I still don't recall my 6th Gen back in 2001 being the same, possibly age has taken it's toll on this cars suspension in general. Overall the car does feel better since originally driving it, I reckon the two new tyres it got on the front made a worthwhile difference.
Anyway here's an updated detailed account of the work carried out for those interested.
Service: Eng. Oil & Filter, Air Filter, Pollen Filter, Plugs, BFC, Wiper Blades, Timing Belt, Balancer Belt, Tensioner & Pulleys, Crank Oil seal. Checked for OBD codes and a general inspection including a road test. Plus: 2 x Tyres & a n/s Mirror Glass.
I've attended to: Front side light bulb, Hazard Warning Light switch bulb, Remote battery and Injection cleaner (will be using it initially for the next 1,200 miles or so).
Next, the to do list. Some are very important (see items 1-3 ) including a full valet along with claying & polising the paint!
1. Fit Leather St.Wheel - ordered from eBay.
2. Fit Leather Gear Lever gaiter - eBay.
3. Fit plain black alloy JDM Gear Knob - eBay.
4. Cut & Code original new Honda Key - eBay.
5. Fit 'new' Remote case - eBay.
6. Change Fuel Filter.
7. Gearbox oil change.
8. Engine coolant change.
9. Clutch fluid change.
10. PAS fluid change.
11. Set Tappets. Rocker Cover gasket kit - eBay.
12. Strip & clean: ERG valve & Plate, Throttle Body & Air Valve. Fit new Injector seals - Honda for the gaskets and seals from an Fuel Injection specialist.
And them! :
Fit Oil pressure & temperature gauges & look into getting better stereo speakers.
That's it so far!!! :lol:
I've done close on 4,000 miles (now nearing on 89k) since purchasing the car in early Oct and overall the car is going well. I've now attended to:
1. Gearbox oil change.
2. Checked tappets (perfect, no adjustment required on any) and fitted a new Rocker Cover gasket.
3. Fully charged the battery.
4. Changed the engine oil & filter (only 2,000 miles since last change), won't do it again for 5-6,000 miles.
5. Fitted duel tone horns, as the original single tone was very poor.
6. New genuine key cut but not programmed yet & new remote case.
7. Fitted a set of upgraded h/lamp bulbs & sanded/polished both lamps.
8. Fitted leather st.wheel, leather g/lever gaiter, JDM black metal g/knob (too cold!) & leather h/brake cover.
9. Fitted oil temperature & pressure gauges - especially delighted in having a temp gauge.
10.Replaced cigarette lighter bulb.
Still a few bits to do but not having a garage where the car is parked up really doesn't help this time of year.
I have noticed a few problems that have arisen since buying the car. There's now a slight flat spot when taking off in 1st (dodgy lambda sensor?), applying the brakes initially feel poor and I suspect I might have an n/s/f drop link on it way out. I'm still not happy with suspension (too much front end float for my liking) so I'm hoping to fit the new shocks that I have, soon. Also, an engine noise has developed at 1500-2000rpm (sounds like a dry bearing), suspect it's coming from the alternator or pas pump, just hope it's nothing got to do with the cam belt kit that was recently replaced.
That's it for now folks!
