West Wales Dave
- Messages
- 2
- Reaction score
- 0
- Car
- Honda CR-V 2.2 ctdi
I have this CR-V with very poor cold start problem. I understand the system is similar on Civic's and Accords. Over the past couple of months its become harder to start, perhaps because the weather has got colder over the same period. I noticed the heater plug lamp was going out earlier and earlier over the weeks, and also, when it did eventually start, it would idle at its normal speed rather than being slightly raised for a minute or two.
A fault code had been logged, heater plug problem and battery voltage. I had suspected a failed heater plug, so removed them all and tested them, perfect. The relay "timer" cutting out too soon, fitted a new relay, just the same. And although the heater lamp goes out, the plugs are still energised for another 15 seconds or so. Not a whisper of smoke out the exhaust while cranking, for maybe a minute before she finally starts, then runs perfectly, all day. Starts ok with a slightly warm engine. I get the feeling if it had a pump with an excess fuel button it would fire up straight away. So what's telling the ECU its cold outside and needs more fuel ?? I have fitted a new battery as the old one was about 12 years old, no difference. Engine coolant temperature sensor replaced, MAF sensor replaced and now getting fault P0113 Intake air temperature sensor circuit high voltage !! With the original MAF sensor put back, no faults found. Still doesn't want to start. Any idea's out there. I don't have any data to test the individual components so a bit in the dark.
HELP !!
HELP !!
