Possible battery/alternator/electrical issue?
Accord-EX
N. Ireland
2.2 i-CTDI EX
Ok so when I started my car yesterday there were no issues - I drove about 15 minutes and parked up for an hour while I was getting something to eat. When I came back and started it I noticed an unusual whine coming from the engine from idle which was never there before. I reved and the whine increased with revs which made me think that the turbo was maybe on it's way out however on higher revs it was not present which made me think more of the alternator/pulley region.
I slowly drove for a further 15 mintues before parking up. I checked the oil level etc but everything visually appeared ok. When I tried to start the car again it turned about 4 times really slowly and stopped. The dash lights dimmed with each turn till a clicking noise from the starter was heard so I stopped. I got someone to give me a push and it started on first turn from push start.
I was 1 hour away from home so I decieded to nurse it home and put the battery on the charger as the maintenace indicator was clear, not green. On the way home the VSA and ABS check system lights were flashing along with the fasten seatbelt light from time to time. I did have full power it was not in limp mode but I did notice that the headlights were a lot dimmer than usual and the window was really slow to go up.
I have the battery charging at present and will try to start it when it's finished. The whine from the engine had me worried though- Any ideas?
Happy Christmas BTW!
Sounds like the alternator is struggling or failing. Check the voltage across the battery with the engine running.
The noise was most likely the alternator pulley, knackered. I had the same, whislt the noise was there the interior lights were dim and as soon as the noise stopped the lights came up bright, I bit the bullet and fitted the short belt option and new alternator, everything back to normal, lots of info on here. I am on 198,000 so I do not think the original did too badly?
How much did it set you back carrying out that work if you dont mind me asking?
It started first time this evening after being on the charger a few hours but I could still hear the whine at low revs. within 15 minutes the lights dimmed and error lights came on again.
I'll leave it on charge for a day and check voltages to try diagnose properly
Just to add further to the description- its not a clicking or ratteling noise its a steady whine related to low rpm
I had this earlier in 2014, alternator refused to charge battery or provide power to the systems, weirdly it kind of cleared after some very gentle driving, but it hasn't been right since with either it not charging at low revs but fine at 1700 and up or there's a parasitic drain...
I'm wondering if its the pully or if there is still some other fault that's been unresolved
My voltages were under 12 volts with a meter permanently attached, when it cleared it slowly rose to 14.. I wonder if although the voltage is right, its just not giving sufficient current?
I've never had any problems with the alternator on my car, which is the 2.4 petrol ...so I don't know much about the alternators on the Accord
But, the issue does come up fairly often on the diesel, and IIRC the alternator pulley has an electric clutch.
The issue was the alternator- I got it refurbished and its now running smoothly again and charging the battery
Nice to see the original poster coming back and updating the post.........:)
