Need some advice on an oil leak I have. Basically the car is leaking from the crank seal which will need replacing, unfortunately I will have to give the car to a garage to do this as its a bit beyond my basic knowledge of maintenance.
The mechanic says the engine needs to come out, so the labor cost will be £120, does anyone know if the engine really needs to come out? there seems to be conflicting information, as the timing belt needs to be removed and possibly changed if oil contaminated, so I would ***ume myself the engine needs to come out for this.
