SEL RESET Button
jimlington
wolverhampton
2010 EX Diesel Auto
Hi all.
Bit of a weird one. I recently had some work done, fitting a new air con condensor. Not sure if its connected but my SEL RESET button on the steering wheel doesnt work anymore. The up and down arrows are fine but I cant toggle between TRIP A or TRIP B and cant reset the trip computer anymore. Driving me slightly mad.
Any ideas please?
julekasMobilek
Vilnius, Lithuania
honda accord
my first though is that steering wheels spiral/clock spring cable is broken.
***uming that other buttons working - hands free, voice command, cruise control BUT sel reset button.
The only explanation is spiral cable, clock spring is broken. It has about 18 contacts for all the buttons on steering wheel, i sugguest you to try to connect and disconnect it, just to make sure.
Not an super expensive part, you can buy aftermarket for about 20euros, or original, from scrap yard for about ~60euros
F6HAD
Affiliate / Co-Founder
Staff member
Halifax
2009 Accord IDTEC
Could just be some sort of a software glitch in the cluster. Have you tried disconnecting the battery for an hour?
jimlington
wolverhampton
2010 EX Diesel Auto
Thanks F6had. Good idea, Its seems a coincidence that the fault occured after having work done and I ***ume they disconnected battery at the time.
Will give it a go!
Channel Hopper
KT8 Postcode
Accord 7 Estate 2005
If you had the work done then I would check with the garage before trying anything yourself, just in case 'the claimed faults were something outside their control and could not possibly have been down to their workmanship'.
Clock springs are not particularly expensive, but their fitting can be if you need to take it - back - to a garage if/when the fault does not clear.
julekasMobilek
Vilnius, Lithuania
honda accord
i have had experience. I tried to take steering wheel of for third time (refinishing the leather, making steering wheel thicker), and for the third time forgot to disconnect clock spring off steering wheel, i janked steering wheel with all the clock spring, and those spaghetti like wires all over the front seat and me :D
i had a bad day.
in addition to this, i am attaching some photos, if intrested:
old wheel:
jimlington
wolverhampton
2010 EX Diesel Auto
Wow. That new steering wheel looks brilliant.
Thanks for the pictures. They would have helped a lot I tried disconnecting the battery for an hour and that didnt sort it, then I tried spraying compressed air on the button and it must have cleared some dust etc and it worked!
