I had a slight hesitation when I bought my CTDi, but the Elite Remap really highlighted that there was a problem.
I cleaned the swirl valve, MAF and MAP sensors, EGR (although, I think, not properly) and what parts of the intake manifold I could get to, but this didn't change anything. I then read the Freq Solenoid Valve TSB posted by CJ, and disconnected my FSV to check. The car then drove great, but put out a lot of smoke on acceleration.
I then replaced the FSV and filter, but, although it's improved, and there's very little smoke, the hesitation is still very noticeably there and really spoils the car. I'm now running with the FSV disconnected again, but am really considering jacking this car in, as it's really getting me down now after over 2 months of fiddling about.
I could use advice on the following please:
1 - Am I ok running with the FSV disconnected in the interim, as I don't know what else the Freq Solenoid Valve controls, or affects.
2 - My replacement FSV has the part number 101360-4800, FRS3 and 480 on the unit itself. This doesn't seem to bear any resemblance to the redesigned part number that CJ posted: 36190-RSR-E01 - is it the correct part?
3 - If the FSV is the correct one and bearing in mind what I've done already, I don't know what to do next . To me after reading all the threads it could be down to any one or several of the MAF, MAP, EGR, FSV, EVR(?) or something else entirely. Most of those bits are expensive and I can't afford to just start changing parts at random. I also don't want to take it to my local dealer, who'll probably adopt the same approach, but also charge me labour on top of that. What would be peoples suggestions on what to do next?...
(PS: If anyone says 'buy a Petrol' then they can sod off!!!
