beneverard
Hello all,
I have a 2004 Accord Tourer and the tailgate will not open, I've already done a bit of poking around, here's the story so far:
Current Symptoms
I've experienced a water leak via the roof rails, very similar to this post where the seat belts on the B pillar were getting wet, as well as water pooling in the boot. I caused this issue by strapping items to my roof too tight, pulling the roof rail mountings out a little.
I've fixed this by sealing the entire roof so we're all good there, but when it was leaking it was coming right through the tailgate motor, not cool.
Tried So Far
So that's that, any further suggestions? I've heard there's a tailgate ECU, but not sure where it lives.
Cheers,
Ben
Current Symptoms
- Tailgate warning light is on
- Very cheap fault code reader returns no error codes
- Neither the boot handle, nor boot release on the key fob open the tailgate
- Can only open tailgate using catch inside
Tried So Far
- Fixed roof leak
- Replace blown 20A tailgate fuse
- Plenty of "tailgate resets"
- Stripped down lock mechanism, cleans two white position sensors
Cheers,
Ben
