I'm having problems with the nsr brake on the tourer, originally started with excessive heat and squeeking (it had worn 1 pad to metal) so when I replaced the rear discs and pads I cleaned everything up and its all been fine for the last few months.
Then tonight I could smell that horrid smell again and sure enough red hot rear disc
So the plan of attack tomorrow is to strip down the brake and check the caliper, see if it slides ok and that the piston will push back in and then check to see if the pads are siezed in the holder.
Is there a way to tell if the brake hose is at fault?
I've read through the posts on here I'm just hoping its something simple however it may be getting due a caliper if its playing up again only a few months after being in bits
Any advice would be greatly appreciated before the 8am saturday morning spanner throwing starts lol
