Howlinator
- Messages
- 23
- Reaction score
- 5
- Car
- 2009 Accord EX
I'm about to tackle a change of valve stem seals on my '09 2.2 i-dtec. Anybody have tips, photos, videos or write-ups? Looking to do it without removing the head, if possible.
So, I finally got everything back together yesterday and after a bit of bleeding airlocks and some persuasion, I got the car started and it's running smoother and quieter than before and no white smoke on start-up.Are you using the workshop manual for the iDTEC engine? The camshaft removal procedure should be in there. Perhaps one of the cam drivewheels has to come off (guessing).
Accord VIII Service Manual / Workshop Manual / ESM on Windows 11
Hi all. Quick tip to get the Electronic Service Manual (ESM) working on windows 11. Link to the ESM - this will not work on anything other than Edge browser or Internet Explorer Windows 10 or earlier. To get it working on Edge browser on Windows 11 (or earlier) do the following steps. 1. Open...typeaccord.co.uk
I resolved this issue with a Turbo Cleaner Spray. I don't think it was directly related to the valve stem seal job, but possibly became an issue as the car was sitting up for a while when I was doing the seals. Maybe just coincidence though.common issue normally tied to blocked vanes caused by dpf blockages. I have however seen a split vac line cause it so check your vac lines from the actuator carefully to make sure they’re not pinched or split especially if it’s only happened after reassembly.
