On my way to Luton. It started flashing randomly now on the journey.
Any ideas what is it? Cant really search from my mobile so would appreciate some advice.
Intermittent charging. The battery is ok. When the AA guy was testing it sometimes it was charging fine then it wasn't.
Car's back home now, so am I. With a courtesy Corsa
Will get my neighbour mechanic to have a look at it. Hope it's something as simple as alternator rather than some electronic module etc
Ok well I am hopeful and will try to find out tomorrow. If it's the battery then I'll get on of HH.
Just one thought, with a flat battery, why would my display go crazy? Check VSA, Check ABS, Check Airbags flashing every half a second, dual AC and Internal AC. Windows had trouble going up so that's like a drained battery. But all the other symptoms? Oh and I did not see the Battery lamp coming on. I'm sure I'd see that if it was on before the lights came on.
It could be what Fahad said a duff cell but intermittent causing the charging problem.Battery has arrived. Fitting it later and having the whole thing checked as well. Looking forward to having it fixed.
BTW, can someone explain why would the alternator not charge at all times and what's the reasoning for this? Should it pick up the charging if my battery was near flat? And I 'only' had A/C and navigation on.
Good result Rob all fit for the HH meet nowGot the battery replaced. The 'light' on the old wasn't green, I guess due to its age, but it was also leaking the battery fluid from around the + connector.
It's charging a lot better, now stays at 14V even with everything on. Will test it tomorrow properly. Thanks for all the advise guys
