I don't know the code, but I do know that the VTEC solenoid can sometimes fail on older Hondas. Could be one possibility. I'm sure some 6th ten dudes will be along shortly to help out.
from other post. been asked if I have changed solenoid yet, answer was no, I questioned whether or not a load of Oil will leak out when I take it off. just so Im prepared with some way of catching it
another point to add Oil level looks ok on casual inspection
Finally, sort of forgot about the fault light for a moment a couple days ago, and nailed it in 3rd.. reached about 4k ish then it felt like I was hitting a limiter, or timing suddenly off for some reason, backed off and it went back to normal again. wondering if that is a limp home mode it's gone into, or some sort of indicator as to the cause? thought I'd add it anyway in case someone can say oh yes that definitely......... (insert fault here) ......
will be looking into this in detail at the weekend, inc. getting the volt meter out to check leads as per link above
