Hello All.
Not sure if this question has been posted in the past, I certainly could not find it.
I have 2.0 SE 6th Gen Accord. I would like to know from others where the correct resting point of the engine coolant temp gauge is on this car ? As a few weeks ago when the outside temperature was below 3 degrees, the car temp gauge would take almost 20mins to reach its final resting pointing.
My car seems to be drinking a lot fuel. Only get about 300miles from a full tank and this includes motorway driving. Therefore, I am not sure if my thermostat is stuck open? As on most other cars the temp gauge usually rest half way between cold and hot once the car has reached idle running temp.
http://postimg.org/image/515vmv5yh/
Also can other 2.0 SE 6th Gen Accord confirm if there engine is idling at the same place as mine?
