Bought a high mileage car which needs TLC - clutch/gearbox, power steering, cracked manifold, whistl
Udai
London
Accord 2.2 i-CTDI
Hello everyone,
First of all I'm new here so let me introduce myself. My names Udai, I'm a mug that bought a clocked car for my wife!
She drives an Accord 2.2 i-CTDI '07 plate, the true mileage of the car is 180k.
I've done some reading on this forum before, thanks to everyone who posts on here it's been a big help in getting our car up to scratch.
The car in general is a very nice drive. We have some faults which we're overcoming step by step, but it general its a brilliant drive.
First of all we had a cracked manifold which Honda kindly replaced for us, glad that's out of the way because we have kids in the car. The smell of diesel fumes can't be good for them.
Next in line we have a whistling sound coming from the engine, this is louder when the engine's cold and when it warms up a bit the sound fades into the background but is still persistant. The sound is brought about when accelerating. Another member posted about this and everyone was racking their brains about it, but I believe CJ solved the problem (I need to go back and have a read and look into this asap).
We have a leak from the high pressure hosepipe from power steering to rack, I've tracked this and its visible. A private mechanic said the pump needed to be replaced and quoted £800-£1000, Honda said it was the pipe which will cost about £300 in total. I've found a 2nd hand pipe from ebay for £65 and have someone who will fit it for £30 so hopefully thats this problem solved.
The big problem for us which I'm hoping doesn't lead to a costly fix, occassionally when driving, and I mean very occassionally...the gearbox won't shift into gear, it will become stuck in neutral and refuse to slot into any gear. For example when we're shifting from 4th into 3rd, it will get stuck in neutral, the clutch is stuck in a half way down position and then flip up rapidly. This normally stabilises itself if we pull over, turn the engine off, wait a minute and turn it on. But I want to get to the bottom of this so we can prevent any further damage/stop it in its tracks.
I know I've gone off on one, but the last problem with the clutch is the reason I'm posting today. Has anyone heard of this before? I'm a rookie when it comes to cars but I've spoken to a few mates that say if its a gearbox problem then it won't just sort itself out by turning the engine off and on.
I'm in contact with the garage who regularly serviced the car, im the 2nd owner and the first one had it as a company car from new. Hopefully next week I'll receive a full outline of the work carried out on the car so I have a better understanding of what it needs in the future.
Thanks to everyone for the lengthy read!
Welcome to the forum. Sorry to hear of your problems mate. Sounds like a nightmare. The clutch could just be new hydraulic fluid perhaps?
I was thinking it could be related to the leak from the high pressure hose, but the steering fluid is completely seperate from the brake/clutch fluid right?
Yes, they are separate. Clutch problems aren't unusual on the diesels, but this is a new one on me... I agree with Steve that this is a hydraulic system problem, but I also agree with you that this wouldn't normally be put right by turning it off/on. I think a garage should be quickly able to work out exactly what the problem is.
I wouldn't worry about the turbo whine... it is a common thing, but usually it becomes silent when the engine gets warm. But there really isn't much you can do about it, short of replacing the turbo, so you may as well wait until it fails (or at least starts making a noise like a police siren). It may never fail!
Welcome to TA Udai.
As Jon has said I would expect the whine to either be the turbo or a small boost leak.
The clutch sounds like either the master or slave cylinder is sticking slightly. I'm guessing that pulling over is just giving it enough time to slowly release and go back to normal. Try changing the fluid first as that is the cheapest then go from there.
Welcome to TA Udai.
Haha Jon you've just given me a shocker! It's already started sounding like a police siren, I kept looking in the mirrors the other day convinced a police car was behind me and then realised what was going on.
I've done some reading about the noise and came across this:
'I fixed the siren like sound by loosening the air tube going into back turbo, I wiggled it a bit (there is not much play at all) and re-tight. One bolt hold this in place. And it was gone, must not have been seated right. Hope this might help another newbie like me.'​
Being a rookie I don't know what to make of it, think I found the turbo behind the engine but its out of my depth so I will ask the mechanic to have a look when he fits the high pressure pipe.
So you guys think I should try and change the hydraulic fluid? Where/how would I do this? I don't mind giving it a shot before I see the mechanic if you think its easy enough, happy to learn as I go along....infact I really enjoy it.
I don't want to frighten you but my old Accord did the police siren noise and about a day later the turbo went pop.
There might be a diy on here for bleeding/replacing the clutch fluid but basically you have a small fluid reservoir under the bonnet near the bulk head. Master cylinder is at the pedal and slave at the gearbox. Open the bleed nipple pump the pedal and top up the fluid before it drops too much.
try bleeding the clutch, mine turned out to be the clutch/dual mass flywheel and had the same symptoms as you but could also be master cylinder.
Think I found the clutch reservoir courtesy of a youtube vid showing how to do it on a civic, its a little out of my reach but not impossible if im looking at the right thing. Will take some pics and upload over the weekend to make sure im looking in the right place. Is there any danger of getting air into the system if I don't do it right?
I've just had the rear brake discs and pads changed, they also drained the brake fluid, replenishing it. Still a little confused, the brake fluid and clutch fluid are completely separate? I was under the impression they run from the same system.
I've been doing some digging and got hold of the cars entire service history from new which is a blessing, its had a new clutch/dual mass flywheel at 104k miles so dont think it could be that giving the trouble, although were at 180k now. Also I see the last engine oil used was part synthetic and I believe this one should be running Fully synthetic 0w30 so I've got some Castrol on the way. Entire service history below, feel free to comment/make suggestions on anything you think I should ask the previous garage or do to the car. I've highlighted some key areas in bold inc some engine trouble
Date 08/10/2013 Mileage 174892 Job Value 334.06
Standard Labour 199.75
Diagnostic check / reset 0.00
Parts Qty Value
0281002659 Rot.-Speed Sensor 1 69.56
PS Part Synthetic Engine Oil 7ltrs 19.50
Date 25/02/2013 Mileage 166107 Job Value 343.73
Job Details Special attention to handbrake
MOT 44.00
Replace n/s & o/s/r antiroll bar links 39.95
Replace n/s/f upper wishbone 59.93
Parts Qty Value
GSJ4790 Susp.Arm 1 96.75
632601030 Stabiliser Link Rear 2 84.26
BS1 Bulb 1 0.85
FS Fully Synthetic Engine Oil (Low Ash) 1ltrs 5.50
Date 02/02/2013 Mileage 164700 Job Value 275.21
Labour Value
Attention to eml 39.95
Diagnostic check / reset 35.00
Parts Qty Value
36180RBDE Valve ***y 1 162.52
Date 24/01/2013 Mileage 164129 Job Value 249.93
Labour Value
Full service 67.92
Replace rear antiroll bar bushes, refit n/s headlight clip 39.95
Parts Qty Value
HU718/6X Filter - Oil 1 10.75
ADH22255 Filter air 1 24.51
CU2358 Cabin filter 1 13.55
ADH22341 Filter fuel 1 28.05
FS Fully Synthetic Engine Oil (Low Ash) 6ltrs 33.00
Page 1 of 6MISC1 Screenwash 1 0.90
MISC2 Brake Cleaner 1 1.65
52315SED0 Bush 2 10.92
Advisory Slight engine oil leak from crank seal
Date 10/10/2012 Mileage 156564 Job Value 287.27
Labour Value
Replace front brake discs & pads 67.92
Replace rear brake pads 29.96
Parts Qty Value
GBP1648AF Brake - Pad Set 1 40.19
GBD1646 Brake - Discs 2 91.78
GBP1271AF Brake - Pad Set 1 35.63
GWB913R Wiper Blade Standard Rear 1 9.31
Advisory N/s/r tyre worn bad cords showing through, rear antiroll bar bushes need changing
Date 30/05/2012 Mileage 145558 Job Value 180.05
Labour Value
Full service 67.92
Parts Qty Value
HU718/6X Filter oil 1 10.75
ADH22255 Filter air 1 17.34
ADH22341 Filter fuel 1 25.30
GFE3117 Filter - Pollen 1 12.88
BS1 Bulb 1 0.85
Advisory N/s/r tyre wearing on inside edge
Date 30/04/2012 Mileage 143603 Job Value 469.99
Labour Value
Replace faulty steering lock ***embly 79.90
Parts Qty Value
35100SEAE Steering lock ***embly 1 323.07
Date 18/02/2012 Mileage 139537 Job Value 116.46
Vehicle Details RE07HHN Honda Accord 2007
Job Details Attention to lights
Labour Value
MOT 44.00
5000 mile type engine service 19.98
Parts Qty Value
HU718/6X Filter oil 1 10.64
33303S3000 Bulb 1 1.65
N/A Bulb headlight 1 4.95
Date 16/12/2011 Mileage 134479 Job Value 141.26
Labour Value
5000 Mile engine service 19.98
Replace front brake pads 29.96
Parts Qty Value
FS Fully Synthetic Engine Oil (Low Ash) 6ltrs 33.90
Date 15/11/2011 Mileage 129209 Job Value 10.60
Labour Value Parts Qty Value
FS Fully Synthetic Engine Oil (Low Ash) 1ltrs 5.65
N/A Fuse 1 0.45
Date 15/10/2011 Mileage 129209 Job Value 66.73
Labour Value
500 mile engine service 19.98
Parts Qty Value
Date 30/09/2011 Mileage 128715 Job Value 266.45
Labour Value
Full service 67.15
Change Hydraulic Brake Fluid 15.80
Replace rear brake pads 29.63
Parts Qty Value
FS Fully Synthetic Engine Oil 6ltrs 33.00
MISC1 Screenwash 1 0.85
MISC2 Brake Cleaner 1 1.50
GBP1271AF Brake - Pad Set 1 35.28
GBF4100 Unipart Brake Fluid Dot 4 1 Ltr 1 7.12
BS1 Bulb 1 0.85
GLBH1 Headlight bulb 1 4.95
Advisory Front brake pads will need changing in approx 6000 miles
Date 30/09/2011 Mileage 128715 Job Value 5705.97
Job Details Attention to engine noise
Labour Value
Replace engine ***embly 454.25
Parts Qty Value
37240PHM0 Oil pressure switch 1 29.42
ANT1 Antifreeze 4 7.00
N/A Engine 1 4472.0
GO1 Gear Oil 2 14.30
PSF Power steering fluid 1 6.50
Advisory Vehicle has had full service on seperate invoice
Vehicle will require engine service in 500 miles, then every 5000 miles
Date 18/11/2010 Mileage 104328 Job Value 933.43
Labour Value
Replace clutch ***embly including dual mass flywheel 237.00
Parts Qty Value
22105PGE3 Clutch kit 1 183.26
22810PPT00 Bearing ***y 1 36.80
415027210 Dual mass flywheel 1 368.98
GO1 Gear Oil 2 12.00
Date 08/11/2010 Mileage 104328 Job Value 395.56
Job Details Check clutch , check exhaust, check battery
Labour Value
Full Service 67.15
Parts Qty Value
GFE635 Filter - Oil 1 10.43
ADH22255 Filter - Air 1 8.53
GFE5514 ADH22340 Fltr Fuel 1 11.69
GFE3117 Filter - Pollen 1 12.50
GBP1271AF Brake - Pad Set 1 34.93
GBP1648AF Brake - Pad Set 1 39.40
GBA3096 Battery 1 88.62
76630SEAJ1 Wiper blade 8 68.70
76620SEAJ1 Wiper blade 1 9.16
Advisory Clutch may soon need changing as discussed
Date 09/07/2010 Mileage 91677 Job Value 138.98
Labour Value
Full Service 67.15
Parts Qty Value
GFE635 Filter Oil 1 10.43
FS Fully Synthetic Engine Oil 7ltrs 35.75
91503SZ300 Clip 8 12.96
Date 04/02/2010 Mileage 78095 Job Value 315.59
Labour Value
M.O.T. inspection 42.00
Remove drivers seat for access to seat belt 0.00
Strip down & repair seat belt stalk 59.25
75000 miles Service 67.15
Parts Qty Value
Fully synthetic longlife eng oil 7ltrs 35.75
80292SDC5 Filter element 1 20.00
16901RJLE0 Cartridge ***y 1 29.42
17220RBDE Element ***y 1 18.89
15430RBDE Element kit 1 11.22
9410914000 Washer sump plug 1 0.41
N/A Screenwash 1 0.85
N/A Brake cleaner 1 1.50
Date 03/09/2009 Mileage 62693 Job Value 253.20
Labour Value
Full service + 67.15
Replace rear brake pads 27.65
Replace front brake pads 27.65
Parts Qty Value
15430RBDE Filter oil 1 10.66
941014000 Washer 1 0.31
GBP1271AF Brake pad set 1 33.59
GBP1648AF Brake pad set 1 37.79
Date 12/05/2009 Mileage 51054 Job Value 219.51
Labour Value
Replace wiper blades 0.00
Parts Qty Value
H17220RBD Element ***y 1 17.95
H941091400 Washer plug 1 0.31
H15430RBD Element kit 1 10.66
H16901RJL Cartridge *** 1 27.95
H80292SDC Element filter 1 20.00
Fully synthetic oil 7ltrs 35.75
76620SEAJ1 Wiper blade 1 8.00
76630SEAJ1 Wiper blade 1 8.00
76730SED0 Wiper blade 1 9.00
Advisory o/s/r tyre low on tread
Date 06/01/2009 Mileage 38098 Job Value 207.57
Labour Value
37500 mile service + 57.75
Replace front brake pads 28.88
Replace hydraulic brake fluid 19.25
Parts Qty Value
15430RBDE Filter element 1 10.66
9410914000 Sump plug washer 1 0.31
N/A Screenwash 1 0.75
LP1862 Brake pad set 1 42.59
Date 03/10/2008 Mileage 26298 Job Value 205.84
Labour Value
Full service + 65.45
Parts Qty Value
H1543RBDE Filter oil 1 11.29
H17220RBD Filter air/kit 1 19.02
H80292SDC Filter pollen 1 21.20
H16901RJL Filter fuel 1 29.62
H941091400 Washer plug 14mm 1 1.77
Date 15/05/2008 Mileage 13158 Job Value 97.92
Labour Value
12500 mile service + 57.75
Parts Qty Value
H941091400 Sump plug washer 1 0.31
H15430RBD Oil filter element 1 10.66
LITRE Part synthetic oil 6 17.41
Advisory front tyres getting low on tread
