clutch slave movement
Swallow
South west
Accord mk7 ctdi ex
Hi all - can anyone tell me how much movement there should be in a correctly working clutch slave on a 2007 diesel tourer?
I replaced the master cylinder a year or more ago, which dramatically improved some clutch issues I was having.
Now, I fear that the slave is giving up - it does loose a little fluid over time but not dramatically.
First and reverse gear are proving a little difficult at the moment but will always go in with a couple of pumps of the pedal.
I am really hoping that it isn't the clutch itself/pressure plate.
Have had a helper push the clutch pedal down while I look at the slave cylinder rod movement - so was interested to know if anyone knew what the expected level of "throw" in a correctly operating system is?
Many thanks, Tom
Swallow
South west
Accord mk7 ctdi ex
Scrap that - it is the master cylinder that has failed again... wet with fluid underneath. Not a fun job to change
F6HAD
Affiliate / Co-Founder
Staff member
Halifax
2009 Accord IDTEC
Feel free to share any tips or a write up in the diy section for other members to follow
