Hey Brian, excellent topic!
I'm in need of your expertise....
2.0 petrol, getting slightly cool air, but nowhere near to proper A/C temps.
Can hear the clutch engaged either using the A/C button, or using a wire from the +ve terminal. with the engine running and A/C set to Lo, I don't think it turns off... at least not as regularly as it used to.
I have the self recharge kit and decided to check out the pressure. With the compressor running, the pressure was around 5psi (way below 'normal') so I put about half of the can into the system. The pressure rose, but then struggled to get up above approx 15 psi... I'm presuming this means I have a leak somewhere, but the weird thing is with the engine off, the pressure on the low side jumps round to about 40 psi ?
Is this normal?
Does it sound like I need a new compressor?
I have also recently had the bumper off and noticed that the condensor is the worse for wear.. If I'm driving at motorway speeds, it does get cooler, so it will most likely need replaced too.
Cheers,
Matt.
Is this normal?
Cheers,
Matt.
