Sheffaccord
Hi all,
Old git here with very limited technical knowledge but keen Honda driver. Engine management light came on so took car (7th gen Accord Exec on 55 plate - 86k) to main dealer. Fault code related to Baro sensor and code will not clear. As sensor built in to ECU, a new ECU is required. Will only cost £1,094.27 to replace! A tad concerned about this so did some research and sending to somewhere like ECU Doctor seems a reasonable bet. Two questions (but come back with as many answers/recommendations as you can please).
1) Do you know anything about ECU Doctor or would you recommend someone else?
2) Where is the ECU and is it easy to get at and get out?
Thanks in advance.
Thanks in advance.
