My diesel seems to sit slightly below half way on the gauge though it warms up quick enough. Is this normal or should it sit bang on half way?
Has anyone noticed this actually working?
Thanks Matt. I can't say that I've ever noticed mine working!Yes, but it's less than amazing. As far as I can tell it operates WHENEVER the engine coolant temperature is below cabin set temperature (even for the first few minutes in the middle of summer) -even if the A/C is set to off. The only way I've found to stop it entirely is to set the temp to 'LO' (with A/C off). Conversely, in the depths of winter, setting the temperature to 'HI' gives the best gas ***isted heating effect.
There are a few threads around on this one...
