Hi guys
As explained previously my car is 56 plate CDTI with 34,000 miles, full Honda service history and clutch slipping when accelerating.
Contacted Honda dealers recommended in London and chose South Ruislip as they were the supplying dealer, were recommended and could look at the car this week.
Nice people, they have provided me with a courtesy car whilst mine was being repaired and agreed to represent early failure to Honda UK.
They stripped car today and invited me into Workshop to see the clutch.
Looks original, friction plate appeared to have no wear (7.62mm thick friction plate) have fitted new plates with less meat on them.
Pressure plate again looks standard honda supply, no blue marks or high spots and surface of plate looks excellent.
I saw what appears to be torsional springs on the outside of the clutch spring fingers, but the plate did not seem to have any means to self adjust spring tension onto friction plate.
The smaller springs around the plate appear to offer a little damping to clutch engagement rather then adjustment
Can anyone tell me how this works please?
Mechanic also advised that Dual Mass Flywheel was slightly out of spec.
He had marked the outer edge of flywheel and a single point on flywheel, there was 36mm free movement and he explained that the Honda tolerance was 35mm
That apart fly wheel was unmarked and no ridges, blue/ high spots on clutch face.
Decision pending re Honda UK decision.
Second question is does anyone know what the Dual mass fly wheel tolerance should be and if mine is at the outer tolerance edge, how big an issue is that likely to be?
Fahad your post mentions yours was checked, what was your measurement please?
Car drove fine prior to slippage, smooth engagement, no vibration or miss fires.
Would appreciate your views as no doubt a little negotiation will occur and whilst I have years of motor vehicle repair experience I am not familiar with Honda's, rumour used to be that they never go wrong?
ps fuel filter really easy to change once the gear box is removed lol
Many thanks
