Dan Robinson
Grand High Plumber
Nice!
Ross, that's about the same mileage mine went on. Can't see any reason the flywheel will need doing, I know Stoke is a bit of trek for you.. which dealer are you using?
Ask the service manager to give you and if possible, show you the freeplay in the DMF when the box is off. You can buy the LUK DMF far cheaper independently - Honda use the same part and seem to put a massive mark up on it.
Yes of course it will invalidate your warranty mate. Who installed the remap for you?
Don't tell 'em dude - simples.
49k miles and the clutch has just started slipping
Mainly motorway miles, no remap and the previous owner was Honda
The car is scheduled to go in for a service on Tuesday (I have also asked them to look at the rear brakes - the discs have already been replaced once under warranty!)
I'll ask about the clutch and the warranty (car is just under 3 years old)... fingers crossed
155K on original clutch as far as I can tell. I have a full detailed printout from the lease company owner detailing down to each bulb and no mention of a clutch anywhere on it.
I did find out from teh previous owner the car has led what is an almost idylic life, the first 130K was just trundling from London to Edinburgh twice a week. serviced on the nose with whatever it needed. from my ownership at 130K its daily workload is a 54 mile each way mainly motorway trundle. again, serviced on the nose. For a car it doesn;t get much easier. Properly warmed up every time, 5th gear, 2-2.5K revs, job done.
Mine is starting to show a little slip in 3/4th at 2.5K if I'm booting it but I reckon with gentle care i should get another 3-4K out of it before it needs doing. Only problem with that is that I want to get it mapped and I daren't till the clutch is done!
I have print out of history from new till I got it with no bill more than a couple of hundred quid. I spoke to previous owner who confirmed its never had a clutch that he is aware of.
it has always had a charmed life of just being a motorway muncher, previosu owner just drove from Slough to edinburgh and back twice a week so all motorway cruising, I do 54 miles each way to work, ~ 50 of which is motorway so again just sat in 5th @ 2.2K.
I drive with mechanical sympathy (i.e. no high rev slipping clutch starts, clutch fully released before being on power for all gear changes etc ) so very little time where there is any slipage between friction plate and flywheel which is when it is 'wearing'. When locked 1:1 there is no wear at all.
IIRC That bloke with the million mile volvo reckoned he got over 200K from a clutch as well so its clearly possible.
Padraig, I know your car is tuned (not by us as far as I'm aware) it could be that the remap is just too strong for the clutch and also the last installation may not have been carried out properly i.e with the correct adjustments.
