LPG here too, dont forget Diesel wont have that lovely VTEC either, although tbh the VTEC on the K24 isnt worth screaming about but at least its there!!
Also if you are doing the conversion, think of the size of the tank aswell coz i have a 40 litre spare wheel donut tank and I would not be able to complete a straight 280 journey on one full tank. You are probably looking to need one of the bigger cylindrical tanks, which in all honesty isnt too bad as the accord boot is pretty deep so you wouldn't notice unless you needed to fold the seats down to carry something long. In which case you are pretty stuck with a gas cylinder blocking the fold down seat hole and limited gap lol
Just like the rest of the guys, I have not had any problems with running LPG (it was already fitted when i bought the car however, polish conversion too) and it always makes me smile when I pay for a full tank of gas and its less than £30, whereas everyone infront of me are putting through transactions over £70
Petrols are more reliable too, there are no common faults like the manifold cracking, flywheels warping, DPF filters clogging, oil filter problems, heavily sooted oil, etc. Plain old oil + filter change with whatever oil grade you feel sufficient for the needs (I think some people have even tried 10w40! But of course I would recommend fully synthetic if you can) and the spark plugs should last you a few years also. The LPG wet + dry filter changes are pretty cheap and simple too. Plus you get the nice slick 6 gear box to enjoy with that rev range. I find that you will come across LPG stations randomly but you should always know where your local ones are and be prepared to use them regularly if they are out of the way.
hope that helps! Good luck!
