Hi all!
I know that was on forum many, many times but cant find solution for this.
Car goes to limp mode, coil light start flashing after getting more than 3k rev sometime starting at 2k.
there is no problem with start, cold or hot no jumping weird sounds etc. my mechanic told me there is code p1065 which is low fuel pressure.
fuel filter was replaced, bosh from honda. i've replaced copper washer(bought in honda) under injectors (rocker gasket was leaking, changed as well)
but yesterday i've decide to bleed fuel filter again, was doing this 4 times!
was ok for 5 miles and started again.
what do you think, can be problem with low pressure from pump to filter? or injectors itself?
many thanks!
many thanks!
