this guide is for changing the cooler pipe that runs in front of the radiator, and will be a mix of what should happen, and what happened when i did mine.
where i haven't taken pictures myself i have used pictures freely available on google
unfortunately to change the pipe you need to remove the front bumper to get access to the pipe, 1 end is easy to get to under the bonnet, but the other end is hidden behind the bumper.
Tools:
small flat blade screwdriver
empty coke bottle
socket set with 8mm – 12mm sockets
pliers
turkey baster
rags
honda power steering fluid
Step 1 – drain old power steering fluid
there are many methods on the internet on how to do this, this is what id did.
Remove as much of the fluid out of the reservoir as you can, turkey baster worked for me.
Remove the return line the upper hose on the reservoir then put the line into a narrow neck bottle like a coke bottle.
turn engine on then turn the steering wheel from side to side to get the remaining fluid out of the system , when the system is getting empty the power steering pump will start to clatter.
Even though i did this, later on when i removed the cooler pipe there was still some fluid in it.
the fluid that came out of mine was black, guess its very old or been overworked.
Step 2 – bumper removal
locate and remove the bolts in the front of the wheel well on either side of the car, they should be 8mm socket size but mine were 8mm and 10mm, guess someone had removed them before and lost one or something!
Locate and remove the bolts on the bottom corners of the bumper and remove them, these should also be 8mm
be warned, these bolts get covered in all the ***** off the road and will likely be jammed, i broke 2 trying to remove mine, the 2 i didn't break i wire brushed and wd40'd to death so i could use them again without fear of them breaking in the future.
locate the plastic push pins along the bottom of the bumper, using the small flat blade screwdriver pop the heads off and remove the pins.
On mine there was 1 pin and a few cable ties....
locate and remove the plastic push pins on the top of the bumper, on my 1.8 vtec sport there are 3, but there may be more on other models.
the bumper should now just pull off, on my car there are fog lights in the bumper so i pulled the bumper forward a little then disconnected the wires from the lights then removed the bumper completely.
Step 3 – pipe removal
follow the lower pipe from the reservoir to where it joins to the metal pipe, undo the pipe clip and seperate the pipes
from behind the bumper on the right hand side the cooler pipe is connected to a flexible hose, remove the clip and seperate the pipes, be carefull there might be some fluid left in the pipe.
The cooler pipe is now attached to the car by bolts, 1 in the middle of the cooler and one to the right hand side, remove the bolts, you now should be able to remove the cooler pipe.
Step 4 – replace pipe or bypass
you can now attach your replacement pipe, or if you wanted, replace the metal pipe with a length of suitable flexible pipe.
I got a local company to make me a pipe of roughly the same shape for me.
Step 6 – re ***emble
in true haynes manual style.....***embly is the reverse of disassembly
Step 7 – re fill with fluid
this is the method i used, not sure if its the correct one, but it worked
ensuring all the pipes have been reconnected, fill the reservoir ¾ full of fluid, then start the engine and let it run for a few seconds and stop the engine, check the level in the reservoir and refill to the top mark.
Start the engine and turn the steering lock to lock a few times, the pump might squeal a bit at first, stop the engine and recheck the fluid level, top up if requred
job done!
Any questions please ask i will try to help
Tools:
empty coke bottle
pliers
turkey baster
rags
job done!
