Hi guys, done this to my car so thought I would throw up a guide
First of all, gather the supplies. I got around 200-1200 grit.
To remove the grill, pop off the clips using a flathead screwdriver and pull it out.
Flip it over, there are a few screws here to take out. I have highlighted some of them, they are obvious.
Once these are took out you are left with this:
Then to get the other strip of chrome, pop the bonnet and towards the top you should see four 10mm bolts. Remove these and slide the strip off, be very careful here as the chrome is easy to break like I did to mine...
Then heres how I did it:
Sand, starting with the roughest and moving up
Clean and dry it off, mask if needed
1 layer of etch primer
2-3 layers of grey primer:
3 layers of Arctic Blue:
2-3 layers of clearcoat:
All back together:
Will get some pics of it on the car tomorrow. Cheers
All back together:
