Sorry to hear this mate but a good result from HUKThe VSA failure has just been confirmed on my April registered 2005 Accord Tourer iCDTi with 53K on the clock.
Obviously out of extended warranty by some 7 months but within the 62K mileage limit.
Aylesbury Honda contacted Honda UK immediately without any prompting and came back within 30 minutes with a £700 contribution to the part cost.
I resent having to pay anything for a defective component but I am very impressed with Ray at Aylesbury Honda.
Bad news mate, you're better off buying second hand in my opinion.
Have finally got fed up with looking at the VSA light - it has been on for well over a year - on my 2006 Accord with 84k miles and decided to take it off the road post Xmas and send part off for repair. Can anyone suggest where I can find what used to be called a "parts book" or exploded diagram so I can see what I am doing / need to do? Thanks for any help.
Have an 03 2.4 type s tourer and every now and again the VSA light and exclamation light come on & stay on, always after turning engine off and back on again it goes out and has only happened 3 times in as many years. Have seen the exclamtion come on in snow etc when the VSA system is working so I am guessing it's functioning correctly. Just wanted some advise of what to do, if anything. cheers...
have you had a quote for repair of the unit?be interesting to hear bud.
If the light comes on, but then resets itself when you turn the car off and on again, it's probably a sensor mis-read rather than anything. To determine the actual sensor fail you'll need to get a diagnostic error code dump from the car and this generally can only be done by equipped Honda diagnostic equipment (e.g. SnapOn, etc). The Petrol VSA units seem more solid than the Diesel ones, but the ABS sensors can still fail.
You might be right Dan but i no its an electrical fault inside the unit that fails.I think its usually the pressure sensors.
Does anyone on here know how to use the HDS coz I cant get mine to work?? Pm me pleaseeeeeObd readers won't touch abs related faults. You'll need Honda hds or snap-on readers.
Interested to hear if anyone has success with ECU-testing or similar. Been driving around with my VSA light on for a year now, but going to have to get it fixed this year due to the MOT change. Not happy. Mine failed at about 75k miles, Honda have said they will contribute (I have full dealer history) but won't discuss how much until I have the fault code read by an official dealership (for which they want £50). If I could get it sent off and repaired for £200-£300 then that's the option I'd go for.
With ***istance of a mechanic, we / he had the VSA modulator off the car is about 75 mins without bumper removal . Did need to move a few brackets holding things like power steering reservoirs around as space is very much at a premium. Needed to take care with aluminium pipe for aircon. - also having small hands seems to be a help!! Would expect to remove it quicker next time (!) as this was very much a learning experience. Also, had to make up some blanking plugs for the brake lines to avoid them "dripping" over the time the unit is off.
Left the modulator into ECU this morning and was told it should be ready by Thursday. Expecting a call tomorrow to advise costs of repair so time will tell.
