You do really need to have the codes read to know what part needs replacing... buying your own reader would probably be the best option, imo, but make sure it'll read all codes (including those connected with VSA issues),
If you need a sensor they're much cheaper if you buy from a US supplier, but you need to buy one for a Honda Acura TSX (but not the US Accord, as it's different).
EDIT: If you have a multimeter/ohmeter, then you could go around all wheel sensors and check the connectors to see if one has gone open (or short) circuit. But I can't think of how you'd check the main VSA unit
Found a reader on amazon called maxiscan ms309 ,,,, anyone confirm this will read honda codes ok ??
