if you get to swapping a post facelift 7th gen ECU into your car and get it working without piggy-back to begin with, you deserve some high pointage m8 B)
You can reflash your existing ECU just fine, and you have a local dealer in your area, too.
Check here : http://www.tsxclub.com/forums/ecu-tuning/83138-hey-european-guys-reflash-cl9-cu2-developed-tested.html
I've already reflashed 5 cars, including a pre-facelift CL9 , facelift CL9 and CU2 and all customers are very happy.
Your local dealer reflashed 3 cars already.
All ECUs i see here can be flashed easily, i dont know why piasini said they arent flasheable. Any 705x cpu can be flashed and all Honda petrol ECU are based on em. Get a datasheet, find pinout and go )
you need to take the ecu out the car.and post up your ecu code.if the code is RBB E02 we can reflash your accord.needs to look like this.im littlebo uk dealer.
