Hey! Just bought my 2004 2.2 I-CDTI Tourer a couple of weeks ago and I am so happy.
Though just after a few days, I noticed that the previous owner has probably been removing the CELs, or maybe just has been lucky - and I've got the P2004. Stuttering has become worse over time (it's more frequent) - well okay, the vacuum leak is developing.
But also I'm now dropping quite a lot of black-ish smoke under heavy acceleration - I hope this is the cause of the vacuum leak and nothing else? It would make sense that the mixture is not correct due to the vacuum leak and the flap not being able to operate properly.
Fuel consumption also isn't what I was hoping for - but it is not that bad
http://www.spritmonitor.de/en/detail/714305.html
I took a couple of videos and made this clip for reference:
https://www.youtube.com/watch?v=8OvI76Bt_Nk&feature=youtu.be&t=0m23s
As so,
Could somebody confirm that they got black smoke with this error code? Should I start by still cleaning MAF, IMRC Valve, EGR? Or just order the part?
Also the error code seems to disspear on its own, though - if I move the flap manually all the way in or out, the code does not dissapear - as it did for some owners.
P.S.
Additionally, under high RPM - I've got terrifying white smoke coming out of the engine (what seems like the back of the gasket/exhaust). What the hell could that be? gasket? or some overflow valve? I suppose I need to open up an another thread - or use search first
I thought that the accord had quite a bit of turbo lag, but mine shoots forward at around 1.7k - 2k, is this related to the smoke? Leak somewhere? (The turbo is at the back of the engine, where the smoke is coming from, isnt it?)
