Hello to everyone in the forum.
This is my first post but I'd like to give special thanks to the most prominent members who really show an interest in the discussions and make an effort to be useful.
I have been studying the forum for a long time and only post now because I got my problem solved, so I can give an account of my own case in just one post.
I got a 2004 pre-facelit iCDTI which I bought used (150 000 miles now)two years ago. The only problem I found with its history beforehand is a wrong oil grade in one service but it didn't seem to make much difference to be honest.
I always noticed a slight hesitation when accelerating. I know now it is a very common thing and maybe more of a "personality" trait of the engine. I have driven Mercedes with just the same sluggish behaviour....they're just not race cars, is my opinion!
Now, to the real problems:
1. December 2010 - Service done at dodgy garage. I only realized this later and thought it had something to do with the problem, but now I know it wasn't.
2. A week later - while gearing down to overtake, massive loss of power! To be clear, it wasn't limp mode, and there were no warning lights.
3- From there on: really low power, specially at low revs. It felt like 80bhp instead of the normal 138.
4- January 2011: took it to Honda (Shrewsbury- I'm not happy with them; can explain more if you want) for a diagnosis: they changed the fuel filter and found an "Insufficient EGR flow" code. Cost was £800 with labour, which was prohibitive to me.
5- February: I replaced my EGR with a (low mileage) used one (cost me £50): no difference.
6- Cleaned all the soot and oily gunk from the EGR airways, EGR cooler, intake manifold, IRMC valve, MAP sensor,...all I could get by myself. No difference. Just for info, I also pulled out the glow plugs and scrubbed them; they were a bit calcinated but it was no problem.
At this point, a simpler description of the car behaviour would be it felt like it was choking. I gotta say that I was doing regularly 50mpg at this time which was strange but felt good.
7- March - I took it to a trusted mechanic (this guy supports racing teams....OK, I know he doesn't support DIESEL racing teams...) to do a long promised remap and diagnose the fault. He found a leaking pipe in the EVR (yes: EVR) vacuum line (was not the problem).
7.1 - Immediately after the remap the car was good but we quickly found another problem: low turbo boost at high revs (while connecting the car to his diagnostic kit). This is because the remap lowers tolerance and highlights underlying issues, apparently.
7.2 - By stripping the turbo airways we found a leaking intercooler. It was drooling with an oily residue! It is interesting to note that it wouldn't show up in the normal smoke test: that is because the smoke pressure is not high enough.
Car smoking a lot after this but power a bit better (think 100bhp). The smoking decreased gradually as (me thinks) the ECU learnt the new environment, after a couple of tanks. Economy dropped to 40mpg.
8- April - I replaced my intercooler. Again with a used part from a low mileage breaking car. £80 instead of £1000...Made no difference.
9- May - Smoke tested again: now I had smoke leaking from my EVR.
10: May - I replaced my EVR (used part again). No difference. To be honest, I think that it is normally supposed to leak some gases to stabilize the vacuum line, so it WOULD fail a smoke test.
At this point, I am thinking: was it the dodgy service? Were the used parts no good? Is it something silly? Should I try disconnecting the IRMC, frequency solenoid, EVR, EGR, MAF, MAP...etc, one by one, to see if it makes any difference? It has been suggested, but I don't have the kit to clear fault codes myself!
Finally, I took it to Holdcroft Honda today. I must praise the only two people who I spoke with: Steve the Service Manager, whose first act was to get in my car, drive it and listen to me. And Tony, who was at the reception but he sure seemed to be very experienced.
I just needed to mention the Forum and I was offered a discount on labour. Finally, I paid a very reasonable amount for the time they spent with the car.
You want to know the diagnosis? Well, it was very simple but who'd have thought????
The plastic cover for the air intake was loose. One of the fixing plugs had fallen off and the cover was being sucked in, as the intake created vacuum. That meant not enough air into the whole system. Pretty straightforward, huh?
All they did was to fix the cover back in place...
I can post the pictures here if you want me to.I have many for all the stages of this process, but it seems like I have to post them via a web link, and I'm as good with computers as I am with cars, so let me know and I can send by email.
So, that's it, my story. To be honest, I think this problem is one in a million but I may be surprised...
Cheers!
Estevao
