Jeremy the new valve will probably cure the P2004 but sounds like your EGR might be sticking causing the surge of power. The whole loop can be disabled as part of an engine remap, details in my signature below.
Hi Martin, no mate, resetting the ECU should make no difference - the part either works or it doesn't.
I know I must sound like a broken record over this, but if you've done your fuel filter already then next most likely cause is a stuck/sticking EGR valve.
Have you tried this:
http://typeaccord.co.uk/forum/topic/1517-maf-map-sensor-cleaning-imrc-valve-cleaning/
Might be worth a go, and if you can do it yourself it's a cheap fix.
I believe they are supposed to be up on at low engine speeds ..
Hi Jeremy,hi, no expert here but from my own experiences have you removed the air flow meter and tried spray cleaning it with electrical contact cleaner?? Only a quick job and might be worth a go??
Hi Jeremy,
I have cleaned all of the sensors i can think of and still I have this problem. I am taking back to the local dealer on tuesday to see of they can shed any more light on this. I hope they can as I need the car to tow my caravan in a weeks time - last time i towed it was very embarassing - so slow !! It used to tow really well.
Anyone else got any ideas ?
Martin
Martin,
Depending on whether you have a facelift Accord (say after 55 plate or 6 speed box) then have a look at this thread Link as it sounds like it could be a boost issue, what was done in this thread was he changed two solenoid's around to help diagnose the symptom.
Of course it would be better to get some fault codes, but sometimes they just don't show, perhaps because the failing part has not quite gone. I'm only suggesting the link as it is something you could do yourself, if of course it seems to work, then you will need to replace the part.
It could be that you have a couple of issues one of which is now solved with the new FSV, given the mileage I'd also check the Vac lines for splits.
Any other symptoms you can tell us?
Martin, sorry I've not read your post properly so you may have answered but Low Fuel Pressure (P1064) then it's normally down a poor or blocked fuel filter. A very common issue.
http://typeaccord.co.uk/forum/topic/1019-i-cdti-engine-cuts-out-when-accelareting/
Hi Carl,
Thanks for this. Have checked all of the vac lines and there does not appear to be any splits or leaks and vacuum at the swirl valve control seems ok. Mine is a prefacelift 2004 (54reg). I took it back to the local dealer today and they have diagnosed "low fuel rail pressure" - having spoken with the technician he told me that this was the only test it failed on. It could need a new high pressure fuel pump ( at £2,000 it's more than the car is worth !! ) or a problem with the fuel pick pump in the tank - if it has one as he said that not all models have them. Anybody got any experience of changing the HP pump - the technician said it's about a hours work - just remove the air box and access is quite easy. Having had a look, it does seem fairly straightforward - i just need to find one secondhand !!
Any else I should look at before spending money on a new HP pump . I need to do this so I can sell the car - couldn't sell it privately as would not feel right palming it off on someone else and the same goes for a part ex deal really.
Thanks both for suggestions. Did not get to read them until just now - having boght a pump from a breaker on Ebay. Said it came off a 63,000 car so I bought it. It arrived this morning and feels tighter to turthan mine. Spent about 45 minutes replacing it and guess what - still hasn't cured the problem. When the engine is cold, I get no hesitation or flalt spot at all but as soon as the temp gauge shows warm, the flat spot comes back. What I can't understand is if it's a fuel starvation problem, why the engine pulls like a train when you get past the flat spot. i also noticed when I got back from the roadtest and banging my head against the bonnet, that the engine was lumpy at idle and low revs. I disconnected the FSV - following advice on a previous thread - and the lumpy idle became smooth. I then drove it with this still disconnected and the flat spot and hesitation has gone and the excess smoke too. Obviously, the MIL is on and there is also less power past 3,500 rpm. The FSV is brand new as this is what the fault code showed last week so can anyone explain this ?I agree with Carl that you really must get the actual fault code - if it is the high pressure diesel pump (and/or it's faulty regulator internal regulator valve) then the ECU error code would be P0087 for insufficient fuel rail pressure (this is measured by a sensor on the battery end of the fuel rail), but this fault could also be caused by a restricted fuel supply from the tank to the pump (maybe fuel filter or kinked pipe?) but this would also throw up additional codes that would help to pinpoint the problem area. I suggest you buy a cheap OBD2 reader like I did (on eBay), if necessary. I take your point regarding the cost of a new pump outweighing the value of the car - I was in this position a few weeks ago and was considering buying a secondhand pump (there are usually some on eBay for less than £250) but I did have concerns about reliability. If you did read the above link then you'll see that I put a whole can of BG244 into the fairly low fuel tank and this does seem to have loosened what I believe was a 'sticky' regulator within the diesel pump (and this was probably also aided by my previously replacing the entire complete fuel rail, which probably wasn't faulty but did act to drain all fuel from the high pressure side of the pump which then meant that it had to move a lot of fuel when first started up and this may then have flushed wax/dirt/whatever from inside the pump/regulator). I would have rather performed a 'proper repair', but since the draining of the fuel rail and use of BG244 my car has run absolutely perfectly for over 900 miles (and once it gets to over 1000 miles I'll consider it to be definitely repaired!).
To summarise, if the DTC is P0087 alone, then I reckon it would be worth draining fuel from the fuel rail (as best you can) and sticking a can of BG244 into the tank. ***uming your pump isn't simply worn out, then this might just unstick the regulator valve.
Good luck.
